Sanyo VPC-E760 Digital Camera Logo
Anonymous Posted on Jul 15, 2013
Black screen after recharging the battery, i replaced into the camera, however, when i turned it on the screen remain black.
2answers
Olympus SP-720UZ screen turns on but remains black
Sounds like a hardware problem... You may have to take the camera to a dealer and have them check it out. However, try this first:
Leave the card out for a while, and recharge it. Then reset the camera to factory defaults is you can (check manual).
You may also want to check with the Olympus web site to see if you have the latest firmware update to your camera model. You could try and download latest version and install it.
Hope any of this is to some help... :)
1helpful
2answers
When I turn it on the screen stays black until I
  1. Ensure the camera is turned on.
  2. If applicable, ensure the lens cover has been removed before taking pictures.
  3. Ensure the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. NOTE: Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon [FIG. 1]. This button could be a standalone button or incorporated as one of the control arrow buttons depending on the model of camera.
  4. If operating the camera with a battery, ensure the battery is fully charged.
  5. Ensure the battery is inserted properly in the camera.
  6. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  7. Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
  8. Perform a reset procedure on the camera.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony Service Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Try to reset the camera to original settings:
How to reset a Cyber-shot® digital still camera back to original factory settings. Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
2helpful
Canon PowerShot A480 won't take photo. Pressing on button camera on then pressing silver button to take photo when pressed down screen turns black no picture taken. Batteries new. This is the story; camera...
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
Camera shuts off when plugged into computer wont turn on while plugged in trying to put pics on computer
The camera needs battery when connected. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
NOTE The cameras LCD screen will remain black throughout the transferre.
If you're experiencing that the computer is not reacting to the camera at all try the following:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
2answers
Camera won't power on.
That's what it would do if the battery had no charge. Batteries can only be recharges so many times. Pick up a replacement battery. If that doesn't solve it, at least you'll have a spare battery.
Hi i have a CANON A1000 IS and I just got it a week ago and the batteries lasted me 2 days. I tried charging my camera but when i went to turn my camera back on it said low batteries then immedietly after...
Are you installing Nmh (Nickle- Metal Hydride) rechargable batteries?
If not then your camera probably will not recharege them.
Also trying to recharge non rechargable batteries can cause damage to the battery, and possibly your camera.
Hope this is helpful.
Tom
I just got a toshiba m305 satallite laptop with Vista. I was playing a game and ran out of battery. After plugging in the machin willl turn on and go to the cmos setup screen but then nothing. Just a...
Had the same thing happen to me a month or two ago, Battery recharge is taking up all the current flow for a period of time. Leave it alone for about 30 minutes to recharge, then you should be able to operate the laptop again, but will have to remain hooked to outlet power until battery is fully recharged.
1helpful
3answers
Problem with lens
It is possible you have the display turned off... Some cameras allow you to do this to save battery.
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
2helpful
4answers
'Access' screen?
the (Access) in the screen refer to one of this problem, the lens mechanism is unable to start due to plastic broken parts in it or dust, or battery poor power, use a rechargeable battery over 1200 uAh of power
Top Sanyo Cameras Experts
NOEL
NOEL
Ngoro
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
