20 Most Recent
Nikon COOLPIX S5 Digital Camera Questions & Answers
Camera Screen black
Time for a new camera, the cost to have it exchanged by Nikon is near the cost to replace.
Nikon stopped working
did u try with a new set of batteries.
is it totally dead or getting off after getting ON for few seconds.
plz give info more in detail tat will assist me in helping u more specifically.
Wont turn on
well maybe there is the lince stucked what you can try plugg it to a usb cable and that to a extern cable to the charger cable for usb once you see the light you take the usb cable out of the fotocamera should open now . but propably the fotos have on the side some damage -
I have lens error come up, when i take battery out
Hello
Thank you for using FIXYA!!!
This
is a suggestion. If you do not feel comfortable trying it, you will need to take
the unit to your nearest service centre. Feel free to let me know if you
need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
I dropped my camera, everything
Your best bet is to send the camera back to Nikon for repair, unless you feel confident ordering a new screen and placing it yourself.
Problem with lens
It is possible you have the display turned off... Some cameras allow you to do this to save battery.
My nikon coolpix s5 turns on and dispay remains
The camera's ccd, the image sensor , is either faulty or has become disconnected. This is a fault that can't be fixed by fiddling with the settings. If the camera is under warranty, then return it for repair. If it is not, it may cost more to repair it than to replace it with a new and better camera. They get cheaper and more capable every year- don't spend too much restoring an old model.
Lens cover error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
Use
Firstly ,
Try holding the
Look at the lens ,
Try gently
Another
Try hitting your
your hand.
center for a evaluation to see if it would cost more to repair than to
replace the camera.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
SHUTTER LOCKED OPEN
If by "the shutter" you mean the lens cover, then you have a lens error fault. If you really do mean the shutter then the shutter assembly is not user serviceable and you have to decide whether to get the camera repaired or to replace it.
Assuming you mean the lens cover
then it's such a common fault that I hope you don't mind me pasting my stock
generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common
reason that compact digital cameras get thrown away, but there's a fair
chance of recovering use of your camera again
The fault is
commonly caused by dirt or grit blocking the mechanism, or due to it
having suffered a recent fall. Another common cause is that the camera
was in a pocket or bag and the power button accidentally activated and
tried to open the lens against resistance. The mechanism may have simply
become
dislodged or there may be parts which have broken.
If your camera
is still under warranty and has definitely not been subject to misuse
then contact the Nikon service department in your country to find out about a free repair. If
the warranty has expired though a professional repair will far exceed
the
cost of replacing your camera. You will therefore have nothing to lose
by
trying to fix this yourself.
Please click here
and you will be taken to an excellent article provided by the Camera
Repair website. For the most part, you'll be guided on how to physically
manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good
luck, I hope you manage to use this information to fix your camera.
Please take a moment to rate the free answer I have provided for you.
Cover lens error
try these:-
- connect it to pc and on it
- vaccum the barrel of lens
- changing mem. card and batt. for 2min.
- shake it.
- on and off in different positions
- hit the part near lens softly with palm (trust me this made mine work)
Nikon D80
Press up/down on the multiselector to change views. It's in the section under Playback.
Nikon coolpi l18 is not being recognized by my computer
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for
about 20mins. Plug it all back in. Turn on the CPU! Also make sure if
your device requires "DRIVERS" or if you have a CD download and install
that before anything.
Nikon CoolPix S5 - Same trouble
I went through the process of sending my camera in to the nikon repair center. it was used very little, in fact it appears brand new. it had never been mistreated, wich is what nikon tried to convince me must have happened because they refuse to believe that they have sold an inferior product. they never told me what is wrong with the camera but wanted $146 to fix it and send it back. the only solution is that everyone send their s5 back to the service ctr and refuse to pay to have them repaired. they e-mail a survey and if we all give them low marks maybe they will decide that they should take care of their customers a little better, especially with todays economy. the survey asks if you would purchase or recommend NIKON again. I told them that I WOULD AVOID NIKON LIKE A SICK CHINESE CHICKEN.
