My bamboo pen and touch is working correctly but when i use the pen its like 1 second late and moves very slowly
SOURCE: Wacom Bamboo Fun Pen isnt working correct
I think you dropped the pen on its tip and broke the little ferrite sensing core. You can try to repair it by gluing the core back together - it worked for me. For detailed instructions on how to do it, go here:
http://wishidknownthat.blogspot.com/2009/04/fixing-wacom-bamboo-pen.html
or you can try to swap the core for the eraser and the tip (more involved - you would need to be very good with a soldering iron to attempt this). Either way - it's unfortunate that the pen is so fragile and that the user manual doesn't really warn you of this.
SOURCE: Bamboo Fun won't work w/ provided software
I had the same problem when I got my laptop (Vista OS). The solution is to update the new driver for your bamboo. They are out of date so you need to go here: http://www.wacom.com/downloads/driver-detail.php?id=196 Updated @ Apr. 9, 2009
This update should allow Vista to find it.
SOURCE: Broken Wacom Bamboo Fun Pen
^ I believe this is exactly what you need to know. :3
SOURCE: My Wacom Bamboo Tablet wont detect my pen for some reason
Mabye you should buy a new pen. I had the exact same problem, but I bought a new pen and it worked perfectly. Call first and explain your problem to the website, and they should give you a new pen for free because of warrenty. Go to the WACOM website and look for the phone number in the top-right corner. That is all except to wait for your new pen that should arrive in two or three days tops.
SOURCE: how do you change the pen tip on a bamboo pen?
I posted this solution for a Toshiba Tablet PC that uses a Wacom tablet pen. I am rather confident that it will give you ideas on how to solve your problem.
With the stylus replacement tips there is an extraction tool: It looks like a wide ring split lengthwise.
You take the tool between thumb and index ( as you do a tweezer) and extract the worn out tip. Toshiba warns against letting the tip wear out too much: this renders extraction difficult.
Once you have extracted the worn out tip, insert a new one with the thinner side towards the outside. Press gently but firmly to make sure it is holding.
