My neighbor borrowed my Task Force Electric Mower (model #25143) and ran over the cord. He tried replacing the electric cord, but said the mower didn't start. I can't locate the manual. Is my mower toast or is there a reset button or a fuse that needs to be replaced? Please help.
SOURCE: lawn mower needs new cord to crank the engine. how do i replace the cord
Remove the 3 bolts located on the flywheel housing.(should be 7/16") one in front and two on side.
SOURCE: Instuctions to replace lawn mower deck
Hello
The only thing I can get you is a parts breakdown . If that helps here's the link
http://www.dewaltservicenet.com/SearchResults.aspx?q=cmm1200 and you just have to see the service tag to check the type you have .
Hope this help
SOURCE: Where is the egine model number located on a Lawn
Go to www.lawnboy.com and input the model number of the MOWER and probably any of the serial #'s if you don't have yours. More options and info will pop up and you may get your engine model info from there. I hear that the Duraforce engines are all the same model?
SOURCE: black & decker electric mulching lawn mower won't start
does it have a main fuse besides a breaker ?
