try the casette eject lever located on the right side of the camcorder.has the condensation light come on? if moisture has gotten into the unit the casette may not eject. you will need to leave it for a few hours in a warm dry location for the unit to dry out and try again.
sony is notorious for brand specific the same can be said for their mavica series cameras that can use any mini-disc. unfortunately the best solution is to stay with sony tapes
Mine did that - you will have to patiently keep pressing the clear / stop / pause / etc and even power cycle a few (or many) times and finally you will hear the mechanism release the cassette. Once you hear that - you will be able to eject the cassette. After that go replace the belts.
My MV830 would load without a cassette; but freeze, beep 3 times and eject if a cassette was inserted. I read the following thread with a great deal of scepticism and concern that I would damage my MV830 camcorder even more; but what did I have to lose? I loaded the compartment without a cassette, hit it firmly 3 times on the tape loading side and the issue was gone. It now works perfectly! Technology is fantastic... http://www.fixya.com/support/t238707-will_not_load_tape
Your casette player must have something lodged in it that's why it spits the casette tape back out. If you are able to, try dislodging the player from your dashboard. Shake it and if there's something noisy inside, chances are that's your culprit. Try to get it out by shaking the player while keeping the casette tape door open - like getting coins from a piggy bank. :)
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
The infra red light in the middle of the mechanical deck, that powers the left and right photo sensors is not ok.It looks like a small lamp( you cant see it when it works-Infra red mind it).The video cassette has a large round opening in the bottom towords the front, and accomodates this lamp.please check it out.
My mv830i developed this problem as I was going on my first training flight from Redhill Aerodrome and I was absolutely gutted! My moment of glory and the Canon refuses to accept the cassette. Had to resort to SD card recording. Did'nt get much footage using this method. Anyway on arriving home I sought out solutions from the Internet. I tried blowing any possible dirt from the cassette compartment but to no avail. Then I read about the 'drop it on the carpet' method. Instead of carpet, I tried an old shoe box. After about three attempts from nearly 1 metre - hey presto! It actually worked! The camera took the cassette and all was well again. How on earth this method of fixing was discovered is beyond me - but worked it did for me! Hope it does for you too.
