RCA HD61W66 61" Projection HDTV Logo
Anonymous Posted on Mar 28, 2009
My 61 inch RCA HD TV started to shut of by itself.
About a week ago the tv started to shut off by self, and now when turned on it makes wired noise from back and shuts off.there is a burned out smell.
  • bstone79 Apr 05, 2009
    help please
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
277
Points
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Chi Chu
Level 3:
  • RCA Master 8,457 Answers
  • Posted on Sep 09, 2009
Chi Chu
RCA Master
Level 3:
Answers
8457
Questions
0
Helped
2823059
Points
26282
Ur high voltage is dead.The fly back transformer.Big black block of plastic with a red wire with cap to the CRT(tv tube) is dead.Usally that where the noise came from.
3helpful
Rca tv
High pitched or even fan like noise usually means the Color wheel which are hard to find/expensive for this set.
When you shut set off noise should wind down as the wheel which turns at over 10,000 rpm slows down.
Color wheel
My TV just scanning by it self and the remote
Your buttons on the front panel have stuck or shorted they need to be replaced.
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected]
HD TV Powers off and on by itself
What you need to do is remove the back if your comfortable doing it and test the voltage on the pin marked PSON..its the signal from the main board telling the power supply to come out of sleeping mode and get to work...if that voltage is dropping off then its in the main board if it stays the same when its on and when it shuts off its the power board...Good luck!
Turns its self off
Change the lamp, you can order it from RCA, the instruction manual has order info on page 84.
RCA P61927 NO POWER!!! HELP
If it is a ctc or ptk 195 then you have a bad flyback High Voltage transformer: the large white kindof square thing with big red wire coming out; Must get original RCA part. If picture was good before could cost you a total of (average) $300.00 according to which repairman.
1helpful
Screen TV shuts down
Sounds like an electronic part (a resistor, a diode, etc) that stops conducting electricity when it heats up to a certain point. Maybe it physically loses contact on its circuit board due to a bad solder, or the part itself is internally defective. Unfortuantely you'll need an expensive professional repairman to diagnose it. TVs have high voltages, ya know, and can kill you if you go mucking around inside.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
