My Intel Pentium DUAL CPU E2140 !1.60Ghz(2 CPUs) I want to play 18 WHEELS OF STEEL EXTREME TRUCKER 2 in my pc.http://www.extremetrucker2.com/support.php All the configurations are perfect on my system. But I dont have 2.2Ghz CPU. I have 1.60GHz(DUAL CPUs). ! Can i run this game on System with lite lagging ???
Your game will only require the top amount of GHz when the game is running at it's fastest/most things going on, the rest of the time it will probably tick along nicely and you'll play quite happily but you will get lag or a stoppage at some point....see how it goes..?
If its a free download or you already have the sim, then try it, otherwise if you must fork out your hard-earned cash, probably not advisable.
The 'need for speed', or higher CPU clock-speed, is to allow the sound, video frames, rendering and algorithm calculations to all run smoothly in sync.
Check if they specify 'Absolute Minimum Requirement'.
On my old PC, an iNtel P4 1.6GHz single processor running Win XP, 2GB RAM, I barely managed to run intensive resource-hungry games, but often ended up with a frustrating 'slide-show' or total freeze.
After upgrade to 64-bit 3.58GHz core-2-duo, 8GB RAM, i'm thrilled at SMOOTH performance.
SOURCE: CONFUSION WITH INTEL CORE DUO AND INTEL PENTIUM DUAL CORE!
You are worrying about nothing.
Intel Pentium Dual Core and Intel Celeron Dual Core are both Intel Core Dual processors.
The performance rate is mesured compared to a single core processor so your 2.2GHz dual core will do the same amount of work as a 4.95GHz single core.
Testimonial: "WAIT A MINUTE I NEED ANOTHER REPLY!SO WHAT YOU'RE SAYING IS MY PENTIUM DUAL CORE CAN RUN GRID?"
