I am trying to replace the washer control knob but getting the fron of the knob to release from the front control panel is more than difficult. how do I get the front handle of the control to "let go"?
Anyway the model I got on your problem says it is a Refrigerator...but I can help you to remove the Knob on a washer....first you may have to place a flat head screwdriver in between the knob base and the control panel ..(You may want to place a piece of cloth against the control panel to prevent scratching the surface of same)..slowly force the screwdriver further under the knob alternating form side to side gently lifting up as you do.....(all of this is is premised on the the notion that there is no set screw in view anywhere on the knob)....also most all washer knobs are held in place on the shaft with a little spring loaded retainer that pushes out against the inside of the knob so it does not easily come off.
Hope this helps...please rate me...the Fang
I'm sorry where exactly is the washer control knob on a refrigerator? please send the model # and brand again please.
