18hp craftsman riding mower model#917.255913. won't turn left. i need repair manual.
I have had this problem for the longest time. I replaced the secondary gear twice. Helped for a brief period and now won't turn left again. Replaced the steering shaft and worked for a brief period. Back to no left turns once again. The issue is with the secondary gear and bearings (plastic) which is only a temporary fix. What I had done was welded a piece of steel to the bottom of the steering shaft eliminating the secondary gear connecting directly to the tie rod for the steering. Works perfect now.
Incredible. I tried this and its perfect. Thank you so much ih82bl82001
Are you talking about Steering sector gear ?
PART NUMBER: 136874
and Bearing Arm
PART NUMBER: 154404
Are you talking about steering gear and Bearing arm
PART NUMBER: 154404
You need to get down on the ground and have a look at why it is not turning left. Its as simple as that. A repair will not tell why it is not turning left. Good luck.
THANK YOU FOR YOUR RESPONSE DONNY. MY HUBBY DID THAT TODAY AND THE BRASS BUSHING IS WORE OUT. BUT HE DOESN'T KNOW IF HE NEEDS THE PLATE REPLACED OR THE WHOLE STEERING COLUMN REPLACED NOW !!
more info please.
