The D1660 isn't an answering machine or a voicemail system. Please refer to the instructions for whatever answering machine/voicemail system you have on your phone line.
If you require further assistance feel free to repost your question, but please specify the make and model of the answering machine/voicemail system.
Testimonial: "I do not think this password is from our provider. It has never asked for a password before. I'm afraid I was in my phone options, and pushed a wrong selection in my Menu/Select, Global Setup. There is not a separate voicemail machine attached. "
Is the D1660 the only phone on your line, or do you have another DECT 6.0 (with an answering machine) on your line?
I apologize. I decided to check into my voicemail provider after your answer. They automatically put it on our account, and I had to adjust my settings. Thank you for continuing to assist me. I have solved my problem.
Glad to have been of help :-)
SOURCE: how do i set up the voicemail on a uniden 6.0
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
All Types of Phones
1. Your mailbox number will be the same as your extension number.
2. Default password is 1 2 3 4
3. Voicemail group number is 555 (unless programmed differently)
Before callers can leave voicemail messages you must activate your mailbox and record your greeting message. We would suggest something along the lines of
"You are through to the voicemail of . . . . I am sorry I am unable to take your call at the moment but please leave a message after the tone and I shall get back to you "
To Record Your Greeting Message
1. Dial the voicemail group number (usually 555)
2. Enter your password (default is 1234)
3. Keep pressing 3 to scroll to greeting messages
4. Press 8 to toggle between your two greeting messages
5. Press 0 to change the message and follow the instructions.
To leave voicemail just press 'Release' or hang up.
Responding to Voicemail
On a display phone you will see "You have messages" on the top line and "Display messages?" on the bottom line. Press tick twice to go to voicemail and then enter your password.
On Siemens 'Entry' phone or display phones with a 'voicemail' button, just press this button and enter password when asked.
On ordinary analogue phones you will get broken dial tone. Dial the voicemail group number (usually 555) and enter password.
In all cases you will then be able to listen to your messages.
To delete a message press 0. It will ask you to confirm by pressing 0 again.
