Sounds like an F8 error- problem with the door lock/latch (for self-cleaning mode). Could be the mechanism, control board, or wiring in between. Try unplugging (or turning off the breaker) for 20 minutes to an hour, and plug back in to see if it will reset itself. If you're lucky, you might be able to just clean gunk out of the latch area, but probably need a repair call.
To my knowledge there is no replaceable fuse in this oven. The safety fuse device would be your house fuse or breaker. What exactly is you oven problem? If it is completely dead-no light or anything the problem would be with the house supply to the oven. If you have some indicator lights, interior light but no heat, that still indicates a power supply problem but only with have of the power or what is called one side of the 240 volt system. Possibly a bad or loose connection.
1) If there is a reset on the electronic panel try that.
2) Set the temperature to 200 and see if works then.
3) Put a baking tin in the oven with a piece of meat in it.
4) Uninstall the Wall Oven and take the back off and check the wiring for the elements and the convection fan.
your model says its a 24"
but the hot surface igniter for oven is bad
it should have a seperate one for broiler
check here on fix ya ( hot surface igniter)
try holding the clock pad/button in for 3-5 secs it sould beep and remain on . youve turned the display off. that should reset it. if not give a call to the manufacture. they get a lot of these calls when time changes back/ahead
