Re: Sony 771
problem : buzzing sound no matter what the setting (ie. playing tape, cd, or radio...all buzz the same)
Tried fixes (obviously didn't work):
-blew air through inside
-plugged system into different unit
-cursed
-poked around
The buzz started all of a sudden. The system stills plays CD's, music, radio...but there is that constant buzzing.
Ideas?
SOURCE: Reading CD message
You can use a CD Cleaner as a first step, if it didn?t work the problem need an expert technician to clean the lens or replace it. Good Luck Toufic Malek
SOURCE: sony cmt-hp7 - broken
The unit will attempt an internal reset to start from a known position. If you are hearing mechanical noises, the unit is out of sequence and must be rebuilt. These are not the most straightforward units. If any portion of hte system fails the "startup" sequence, the entire unit will stop. Unfortunately, this may need to see a servicer.
Dan
SOURCE: CD SKIPS
well it depends on how you feel about opening your system. have you tried a cleaning cd? if not, then do that. If not, and u want to open it, then get some electronic cleaner spray (not sure how its called) and blow the laser clean. There are some resistors you can adjust, but thats getting very trick.
good luck
SOURCE: How to play an ipod using the (Audio in) system
On the remote click 'Function' and itll scroll through the settings.
Tape, CD, Tuner, Audio In.
Choose Audio In.
I know this may seem annoying but itll work.
