Band New Maytag Dryer just installed. Touched it the next morning got a strong electric shock. Dryer was not on. Mod medc200xw3
I believe you dryer is not hooked up correctly electrically.
You will need to unplug it from the wall without touching it.
You may need to use a wooden broom handle or some other insulating items to accomplish this.
Remember, electricity cannot flow through dry rubber, paper, cardboard, or wood.
If you cannot move the dryer away from the plug so you can reach it, you will need to shut off the dryer at the breaker box or fuse box before you start to unhook it.
The breaker box or fuse box should be marked on the paper on the back of the door as to which 2 circuit breakers or fuses are for the dryer, but most are not.
You should get someone smart to fix this before you have a fire or someone killed .
Be blessed.
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
SOURCE: Maytag electric dryer mod#DE612 series02
U might want to look on the back of the dryer to see if there is a panel to take off. If not the hole top will have to come off. Is the top made on the rest of the dryer or is there a split between it.
SOURCE: Maytag Neptune Dryer smells like burning rubber or plastic...
could be the board, could be a motor, could be a belt but i would run it intill something just stops or try your best to take it apart and look through things and see if you can see an indication.
SOURCE: Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
SOURCE: maytag ensignia electric dryer makes alot if
I had a squirrel(?) stuck in mine! I removed the lint pipe and it was really nasty. Something had chewed through the screen and climbed down the pipe to stay warm?? We live in Minnesota and it was cold as heck. Anyway, Have a shop vac ready, I hope this helps. Remove pipe at the dryer, push start a couple of times and see if anything blows out. K.J.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Thank you all for your concern. The Maytag repairman came today. He said the Home Depot installer never should of been allowed. Everything is working now. Several loads of wash are now dry and folded.
