Pioneer PL-990 Turntable Logo
Anonymous Posted on Jun 14, 2013
How to adjust the speed using the lights.
Hi, I have one of these but can`t figure out how you use the lights to see if the speed is correct. My record player sounds a little fast but was wondering how the lights help you to get the speed just right.
Grubhead
Level 3:
  • Pioneer Master 5,755 Answers
  • Posted on Jun 15, 2013
 Grubhead
Pioneer Master
Level 3:
Answers
5755
Questions
Helped
1662736
Points
11417
When the turntable spins the light shines on the edge. You will see at least two indications. One for 45 and one for 33. With the record playing you should adjust the speed control, till one of the indents appears static and not moving. You will have to do this for both speeds. You also might see some varations in speed. These are quite normal and getting it right is trial and error. It will only read true when the stylus is on the record too. If you can't get the indication to stay still then there is something wrong with the drive.
Adjust idle
Hi Sean
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Bud
1helpful
Husquvarna chainsaw carb adjusting
Hi Mark
Please take time to rate me
Bud
Nov 24, 2012 • Garden
1helpful
Ignition timing for 1989 toyota corrolla
1988-95 MODELS
See Figures 6, 7, 8, 9, 10 and 11
This service procedure is for setting base ignition timing. Refer to underhood emission sticker for any additional service procedure steps and/or specifications.
These engines require a tachometer hook-up to the check connector-see illustrations. NEVER allow the tachometer terminal to become grounded; severe and expensive damage can occur to the coil and/or igniter.
Some tachometers are not compatible with this ignition system, confirm the compatibility of your unit before using.
  1. Warm the engine to normal operating temperature. Turn off all electrical accessories. Do not attempt to check timing specification or idle speed on a cold engine.
Fig. Fig. 6: Attach the tachometer to the battery and check connector terminals
  1. Connect a tachometer (connect the tachometer (+) terminal to the terminal IG- of the check connector) and check the engine idle speed to be sure it is within the specification given in the Tune-Up Specifications chart or underhood emission sticker.
  2. Remove the cap on the diagnostic check connector. Using a small jumper wire or Special Service Tool SST 09843-18020, short terminals TE1 (test terminal No. 1) and E1 (earth-ground) together.
  3. If the timing marks are difficult to see, shut the engine OFF and use a dab of paint or chalk to make them more visible.
  4. Connect a timing light according to the manufacturer's instructions.
Fig. Fig. 7: Early type of check connector and SST tool (jumper wire) for base timing adjustment
Fig. Fig. 8: Using the SST 09843-18020 or a jumper wire, connect terminals TE1 and E1 of the DLC1 (also used on OBD-II)
Fig. Fig. 9: Ignition timing marks 4A-GE engine-note the small notch on the pulley, this is the mark to align with the degree scale
Fig. Fig. 10: Timing marks 4A-FE and 7A-FE engines
  1. Start the engine and use the timing light to observe the timing marks. With the jumper wire in the check connector the timing should be to specifications (refer to underhood emission sticker as necessary) with the engine fully warmed up (at correct idle speed) and the transmission in correct position. If the timing is not correct, loosen the bolts at the distributor just enough so that the distributor can be turned. Turn the distributor to advance or ****** the timing as required. Once the proper marks are seen to align with the timing light, timing is correct.
Fig. Fig. 11: If necessary, loosen the 2 mounting bolts and turn the distributor to adjust the timing
  1. Without changing the position of the distributor, tighten the distributor bolts and double check the timing with the light (check idle speed as necessary).
  2. Disconnect the jumper wire or Special Service Tool (SST) at the diagnostic check connector.
This jumper will be used repeatedly during diagnostics in later sections. Take the time to make a proper jumper with correct terminals or probes. It's a valuable special tool for very low cost.
  1. Refer to the underhood emission sticker for timing specification and any additional service procedure steps. If necessary, repeat the timing adjustment procedure.
  2. Shut the engine OFF and disconnect all test equipment. Roadtest the vehicle for proper operation.
Honda mower HRU173PU carby screws adjustment
Hi Paul
Bud
Need to tune sthil fs74 line trimmer
Hi chris tanti
Bud
What are the carb settings for ryobi rct 2800 cb trimmer ,they have been adjusted so the correct position of the screws is not known
Hi peter beaufoy...
Bud
Fuel adjustment on a homelite chain saw ut 104002
Hi Alex Sachs
PLEASE, Need carborator. Lo/hi adjustment for Mac #600038-20 18" Chain Saw
Hi mkyhl...
Sep 05, 2011 • Garden
1helpful
What's the correct way to use the strobe light to set turntable speed?
The turntable may have a pattern on the edge of the turntable. If not you need a turntable strobe disk that you place on the turntable like a record. The pattern on the disk or on the edge of the turntable will be marked for 50 Hz or 60 Hz frequency.
The strobe marks on the disk or on the turntable are for 33 RPM and 45 RPM and for both 50 & 60 Hz mains frequency.
To adjust the turntable for the correct RPM, turn on the strobe light and the turntable set it to 33 RPM and shine the strobe light on these marks and adjust the speed setting until the 33 RPM marks appear steady and not moving. You may want to check it for 45 RPM as well.
Make sure you use the correct mains frequency marks ie. the 50 or 60 Hz that your electricity system uses.
Adjusting shutter speed
Hi - There is no direct way to set the shutter speed. This camera relies on the selection of a "scene" mode to automatically set the speed and aperture. All you can do is select the scene mode closest to your lighting conditions or the type of picture you are taking. Something to guide you are the speed & aperture numbers in the bottom of the LCD screen as per 11 and 12 in the picture below from page 7 of the manual:
The other thing you can change is the ISO speed see page 21 in the manual.
Experiment & let us know how it works out!
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
