Ertl 132 Holland L170 Skid Steer Loader-britainsertl Logo
Anonymous Posted on Jun 09, 2013
Hydraulic fluid change on a new holland l170 skid steer,where is drain plug at
Bill Boyd
Level 3:
Top Expert:
  • Ertl Master 53,816 Answers
  • Posted on Jun 09, 2013
Bill Boyd
Ertl Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11950797
Points
172802
On the bottom of the fluid tank. Some have a protection plate under tank and in that case there will be a hole cut to allow access to the plug
Can you tell me the year the Speery skid steer, L452, serial #607295 was manufactured?
Hello, Gary -
The Sperry company has a complicated corporate history, which makes it a challenge to determine where corporate archives (which may include a record of product serial numbers manufactured by year) are located.
- The Sperry company acquired the New Holland corporation in 1947.
- The company name was changed to Sperry New Holland in 1973.
- In 1985 Ford Motor Co. acquired Sperry New Holland.
- Eventually, the corporate name was changed to Ford New Holland (and the Sperry name for construction and agricultural equipment was no longer used.)
- In 1991, Ford sold its Ford New Holland unit to Fiat Geotech, creating N.H. (New Holland) Geotech.
- Eventually, Ford, Fiat and other products were grouped under a neutral, globally-recognizable brand name: New Holland.
- In 2017, New Holland changed its corporate name to CNH New Holland.
Therefore, if your skid steer just has the brand name "Sperry" on it, it was PROBABLY manufactured prior to 1973. However, there is still a challenge regarding the location of the Sperry manufacturing records for its agricultural and construction equipment.
Some New Holland corporate records covering 1902-1906 and 1971-1987 are held by the Lancaster County (Pennsylvania) Historical Society:
https://www.lancasterhistory.org/finding-aids/new-holland-records-1902-1906-1971-1987/
Scroll down the web page cited above to see the telephone number and email address for LancasterHistory.org. You will need to contact the archivists there and find out the charge for researching the New Holland corporate records to determine if records of the manufacturing serial numbers have been retained. When you contact (I recommend speaking by phone) an archivist, I suggest you ask if he / she knows where archival records for Sperry (the unit which manufactured agricultural and construction equipment prior to the corporate name change to Sperry New Holland) may be kept. Serial number records prior to 1971 for Sperry agricultural and construction equipment may be held in one or more other archives (if good fortune had them deposited in an archives.)
Note: At one time I worked as a corporate historian and archivist in the USA.
Best wishes.
2answers
Lost steering to left side of my new holland sl125 skid steer, what's first place to look, trouble shoot
Faulty valve in your hydraulic line or faulty motors. More likely a valve tho. Check output pressure from joystick
New holland troubleshooting
Howdie Best Bet IS Call the Dealer They Will Know It Faster then Me Thks
Hydraulic oil for new holland L553 skid loader
Any auto parts store should have this.
HAVE AN NEW HOLLAND SKID STEER THAT WONT LIFT THE BOOM HAS LOTS OF HYD OIL FILTER ABOUT 150 HOURS AGO ITS AN L555
Check the solenoid down at the control valve, it locks out the hydraulics with a seat belt/seat switch. Check the wiring and connectors on the way down to the solenoid for damage. Remove the solenoid and see if the pin is broke off and stuck in the valve.
Top Ertl Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you an Ertl Toy Expert? Answer questions, earn points and help others
