Cameras Logo
A
Anonymous Posted on Jun 08, 2013
Canon E18 error - Cameras
CameraR
Level 3:
  • Cameras Master 4,738 Answers
  • Posted on Jun 08, 2013
CameraR
Cameras Master
Level 3:
Answers
4738
Questions
Helped
1196070
Points
12483
Troubleshooting steps for a Canon e18 error.
4 Related Answers
fotomohamed
mohamed salim shaikh
  • 321 Answers
  • Posted on Jun 18, 2009
SOURCE: Canon SD890IS Shows e18
connection broken . send ur cam to us for servicimg
Anonymous
  • 71 Answers
  • Posted on Jul 11, 2009
SOURCE: what does E18 mean?
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off. This is caused by dirt in between the telescoping portions of the lens. You can clean this with compressed air, generally. Blow air all around the turret sections of the lens. you can also GENTLY push the lens inward ( have the lens extended and take the battery out... then push inward...)
Anonymous
  • 1566 Answers
  • Posted on Apr 06, 2010
SOURCE: My canon 550 has a len error an saying E18!
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Anonymous
  • 6831 Answers
  • Posted on Dec 19, 2010
SOURCE: Error E18 . What does this mean. Canon camera
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
What does E18 mean on the screen of my camera?
E18 is a lens error. You might try this repair technique:
Canon E18 Error
3answers
E18 error on Canon SD550
do a hard reset to clear the error
Jun 24, 2008 • Cameras
Canon PowerShot A510 error code E18. What does it mean?
Canon E18 error happens when the lens gets stuck while trying to extend. The problem usually happens because dirt or sand get into the lens mechanism. If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
I am getting a message E18
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
In this link could check additional details: e18error.com
Hope helps (remember tp rate this answer).
Dropped my cano a520 with lense out and now I get
E18 error is common error if the lens is broken already
bring your camera to the nearest repair center
8helpful
What does E18 mean?
Jun 18, 2009 • Cameras
The camera was dropped by my son, which happened before, when turned on the canon logo shows then the screen is black. An error message in the bottome left says E1b or E18. Help!! thanks
Here is some information on the E18 error: http://www.e18error.com
A repair guide (suggestions) http://www.e18error.com/repair.html
Forum for users with the same problem http://www.e18error.com/posts/index.php
E18 error on Canon ixus40 - lens stuck
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
E18
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
It's important that you fix the E18 error first, as the blur of colors may be symproms of a failing CCD. If so, Canon would fix this for you for free IF the camera has no other problems (ie no E18 lens error). Please see the following info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
