I cant find a way to change my phone from pulse to touch tone
Here are the instructions for one vtech phone (may not be quite the same as yours but may work or give enough hints for you to figure it out):
Press PROG.•
Press ? or ? until the screen displays DIAL MODE: and the current setting.
Press SELECT. The current setting blinks.
Press ? or ? to select TONE or PULSE.
Press SELECT to save.
SOURCE: Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
SOURCE: can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
SOURCE: changing from pulse to tone dial
All phones have a sliding switch either at the bottom or sides of the instrument. The same is marked with "P" & "T" on either side of the switch, meaning Pulse or Tone. Shift the sliding switch to T for Tone or vice-e-versa.
SOURCE: Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
SOURCE: I need to disable pulse dialing and activate touch tone
When the phone is off, try press flash/program button and then the tone/* button.
