Bsnllive account
I m telling you the way. please do it manually.
BSNL GPRS settings
SOURCE: gprs settings on bsnl postpaid 199 rental on nokia 3110c
well.. u need to contact BSNL customer service people, and they should send u the GPRS settings by sms, just save the settings and use them as your default config settings.
the other way would be to manually configure GPRS by manuallyin addint an access point and other settings, which will get complicated as you will have to manually copy them from other BSNL GPRS enabled phone..
best way is to contact customer service, and they will sms the settings to u..
SOURCE: No gprs settings from bsnl customer care for N73
If you have Postpaid connection then you have to go to Customer service centre of your area and apply there and get GPRS activated on your SIM.
If you had a prepaid connection GPRS is already activated there.
Now for Settings of GPRS - >
Go to bsnl.co.in -> in services go to BSNL Mobile then GPRS/MMS/WAP->Scroll down the page and click on CLICK HERE TO DOWNLOAD GPRS/MMS/WAP setting
In this window
1 > for manual setting - click on Basic details of device settings for manual configuration -> select EAST ZONE as u r in kolkatta -- u will get basic setting for ur mobile......this will solve ur problem ...do remember to keep ur mobile data communication setting on GSM not on 3G/UMTS.
2> for automatic setting select the east zone ...u will get the details there which is self expalnatory
SOURCE: GPRS Problem in my handset nokia2630, bsnl
hi....
think you didnt select your BSNL settings as default setting ,so only your getting as 'subscribe to packet data first'.
As you said it says 'only 20 sets are allowed', there are plenty GPRS settings present in your mobile.please go to default configuration settings and delete all the settings which you previously stored in it.
Now call your BSNL and ask them for the GPRS settings they wil send GPRS setting and MMS settings also. please save it and make it as default settings.Then you can start using the GPRS connection.
If you didnt select it as default setting,follow the below steps to set it,
please follow the steps down to set your BSNL setings as default.
Menu--->Settings---->Configuration---->Default configuration settings.
open this menu and select BSNL as your default service provider,
Then you can start using your GPRS.
Thanx
SOURCE: taraI am using BSNL Prepaid
You can also ask for the settings by sending <make> space <model> of your handset to 58355 by SMS e.g. <Nokia> space <N79> to 58355. After you send the SMS you will in response get several settings on your handset viz. 'bsnl live', 'bsnl stream', 'bsnl mobility' etc
