SOURCE: diesel tractor ran out of fuel now it won't start
You have to take the air lock from the fueling system.
SOURCE: AIR IN DIESEL FUEL LINE
It be probably in the tank,check the pipe that goes inside the tank.
SOURCE: I have a 1990 685 Case IH. 4X4 tractor. It has
something wedged inbetween teeth on gear.
might have to replace the gear... this means chaging all of the gears as they all ware at the same rate, this will cost you a few hundred
