Are you using a desktop or laptop. Is OS already installed on the system? Start your computer and press F2 key while booting and before the logo appears. Check for the boot menu, and see whether your first boot device is your hard disk of the system or not. If not then do that and in case of desktop if you have more than two hard drive just check whether the first boot device is your that hard drive on which the OS is installed or not. I guess, it will resolve the problem. For further assistance, you can avail our technical support by visiting our website: http://www.vtechsquad.com.
this is desktop (tower) every thing is ok ,boot order is from cd, but when i start my computer it is going on boot cd , and give the error press any key to restart , when i press any key , nothing happen i gives again error , ctrl+alt+del is not working , plz anyone tell me what is the solutionthis is desktop (tower) every thing is ok ,boot order is from cd, but when i start my computer it is going on boot cd , and give the error press any key to restart , when i press any key , nothing happen i gives again error , ctrl+alt+del is not working , plz anyone tell me what is the solution
You can't post conmments that contain an email address.
PXE ROM boot is a network boot that kicks in when all else fails. If you have or can borrow a Win7 boot disk, watch the screen closely when powering on the computer and it will tell you which key or keys to press to force a boot from the the cd/dvd rom. If you can boot from the optical drive , it may give you the option to repair Windows. READ THE SCREENS CAREFULLY AND CHOOSE WISELY - if you do not you can overwrite windows and ALL of your personal data. IF you have a hard disk failure, windows should tell you so...
switch to boot devices (F2....F8,)do this as soon as you press power button.keep pressing to bring up bios disable all bootable items in list except cd rom.give this a try good look
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
insert the cd into the cd rom, when dell logo appears start tapping F12 it will give you the option to boot directly from cd. also you can try system recovery if you have recovery partition with ctrl+F11.
If you've disabled the LAN option in the BIOS (or put it at the bottom of the boot order) then forget the CD and go back into BIOS and put the HDD as first in the boot order. If the laptop will not boot to the HDD then it is almost certainly the problem.
I got lucky once with this problem on an Acer by just telling the BIOS to go back to Default and the machine booted normally afterwards.
to go to bios setting either u can hit F2 or F1 key. then u change the boot priority. set it to cd-rom device. after that u can boot from any bootable cd.
for your operating system problem, boot from the xp bootable cd after setting boot priority, and then repair or reinstall your operating system. some files might have been corrupted.
Sounds to me like windows is corrupted. If you have the Windows operating system cd then go into the BIOS and set the first boot device to be the cd-rom. After you do that then put the cd in the cd-rom and then reboot the machine and it should tell you to press any key to boot the cd and it will go into the installation for you and you just follow the prompts from that point.
Test the CMOS BATTERY..TO MAKE SURE ITS GOOD IF NOT REPLACE.If it test good leave out for 5-10 minutes replace.motherboard bios should now beat default settings.reenter the bios.move cd to first boot.save changes.if you do not save changes it will not work.place.computer should now boot from disk.
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC. 1st boot device = [Floppy disk drive] 2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive). 3rd boot device = [Primary Hard Disk Drive] (Model number of drive). Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it). If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation. Or is this not the issue you are having? Good luck! Mike
