After I reformat my phone,it needs code to unlock that I cnt remember bcoz it was a long time ago,now I can't use my phone anymore,can u help me pls to fix this.
Warning:
Do not enter any wrong unlock unlock codes on your Nokia E71-1 mobile
phones. If you enter over a certain amount of wrong unlock codes on your
mobile phone, your phone may get hard locked and sometimes become
unusable.
1 - Switch on your Nokia E71-1 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E71-1.
3 - Compose #pw+CODE+1#.
4 - The Nokia E71-1 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E71-1 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E71-1
Each Nokia E71-1 mobile phone has an unique unlock code. You
can buy the unique unlock code for your Nokia E71-1 mobile phone at www.mobileunlocksolutions.com.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: how to reformat k618i sony ericsson
Hello
You could try doing a master reset but you will lose all data / contacts /pictures/ on your phone
Steps to do a master reset
Settings/general/master reset/reset all/continue
Phone will restart
SOURCE: My nokia needs to reprogram HELP plzzzzzzz!
*#7780# - restores user defined settings to
factory default settings. programs, calendars, and contacts are
unchanged. you will be ask to input your security or lock code to
proceed with the restoration.
*#7370# - reprograms your phone memory to factory default. all files will be deleted.
you will be ask to input your security or lock code to proceed with the
phone memory format. backup your messages, contacts, and other
important data before proceeding. NOTE: this is equivalent to
hard format for Nokia Series 60 1st edition phones (N7650, N3650/60,
N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone
(N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead.
turn ON your phone while holding together the green (call) button, *, 3 - reprograms your phone memory to factory default. all files will be deleted.
important data before proceeding. NOTE: applicable only to Nokia Series 60 2nd edition and above phones (N6600 and up).
SOURCE: i still could not reformat my phone because of the lock code
go for hard reset like this,if nothing works ,this is what I do
Hard Format :
Hard Format can be done if your phone is facing any of the problems mentioned below :
1. Blank screen. Phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Installed some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Make
sure cell battery is atleast 75% charged. If its not then you are
putting your cell at risk. If its atleast 75% charged then do the
following:
1. Switch off the phone.
2. Hold down the following three buttons: Green (call answer) button, * button, and '3' button.
3. While holding these buttons, press the power button and switch on the phone.
4. When the message 'Formatting' appears on the screen, release all of the buttons.
The procedure takes some minutes (approx. 3-4) so dont panic.
Note that you shouldn't switch the phone off or remove the battery when performing either of these operations.
SOURCE: Master security code
please help me...i have a nokia 1112 and i forgot the security code. i try t use a mastercide generator but it does't work.my IM is:359736006161810....pls help me:((
SOURCE: NOKIA N95 reformat code
Nokia phones can be reformatted with a special three-stroke keystroke sequence on power-up. When turning the phone on, press and hold all these three keys at the same time: "GREEN/TALK" ," 3" and " * " when powering up the phone. When formatting begins, release the keys.
Ensure the battery is fully charged.
I lost my BenQ password, the decode number is 20915- 13962-6789-8574. PLease help, thanks.
