20 Most Recent
Nokia 2680 Slide Cell Phone Questions & Answers
Hi - forgot security code
You will get the master code from
mobile-unlocker.com/
and
superunlockcodes.com/unlocking-services/rs12wp6/
IT"S NOT FREE........
Or else you can flash your handset to reset the security code(Default 12345)
To flash you need
*USB cable compatible with your handset
*A Computer
*PC suite of your handset
*Internet connection(Min speed 1Mbps)
To flash
*Install the PC suite
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option)
*Install the "NOKIA Software Updater"
*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Thank you have a nice eday
Mobile thieft
If You Do Not Know Where You Lost it Or Whom Has it Take The Mobile Box Into Your Nearest Service Shop With Your Information And Have Them Block It From Being Used Buy A new Phone And Request It Have Your Old Mobile Number If You Do Not Wish To Get A New Number
Hangs a lot!
The hanging of your phone may be due to low phone memory.Try deleting some data from phone memory.Frequent rebooting of your phone may be due to software problems.Please update your firmware or re-install your phone's software.
Master security code?
You can get the master security code for an affordable cost from any private service. Generated code are wrong most of the times.
Restriction code
I suggest you can approach
Theunlockspot.com and specify the country,locked network.Based on the availability you can get the unlock code along with free instructions for your Nokia 2680 Slide.
