My AWA lcd tv works for anywhere between 10 minutes and a few hours but then the screen goes black and the sounds cuts out. If i turn the tv off for an hour or so it sometimes works again. Other times i have to leave it off for hours. Should I rule out the lcd backlight being a fault as the sound cuts out when the screen goes black. Would appreciate some suggestions for possible faults. Thanks.
SOURCE: Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
SOURCE: Samsung LN-S4041DX 40 in LCD TV
Hi. You can try to go into service mode and reset the LCDTV to Factory Default. This will clear out all buffer over run's and any software related issues. It may fix the problem or it may not. If this doesnt fix the problem than you need to have a qualified Technician to look at it. The problem is in the AV circuit board, a technician who is qualified to repair electronics at circuit board level should be able to repair this problem rather quickly and inexpensively. Most technicians who do not have the expertise in repairing cicuit boards to component level would rather replace the whole AV board than repair it and this will be rather expensive.So talk to the repair shop before you drop the TV off.
Be very careful when accessing service mode. I suggest to write down all information in all areas before proceeding to a factory reset. If you do not record all values correclty you run the chance of not being able to use the TV again. To go into Factory Service mode, use the original remote and in this sequence push POWER OFF-MUTE-1-8-2-Power ON, the set will turn on and enter service mode, if you hit all previous keys correctly. If it doesnt try again. When you are done hit POWER OFF and this will exit service mode and save the data.
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
SOURCE: Blank Screen but sound works on samsung HPS-S5053
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
SOURCE: AWA LCD TV - Blank screen (with sound) - picture appears for a few minutes
Rplace both capacitors on inverter board along with surface mount fuse on other side of board. The caps will aapear puffy on top.
