20 Most Recent Sharp Aquos LC-C3234U 32 in. LCD TV Questions & Answers
You should press the prog: button < / > to change the channels stored in each program. The number of press will depend upon which program do you wish to see. It will be best to buy a remote control for this set, as this set will not have a Menu button on its front panel, as there is only four buttons on panel, as you indicates here.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ If you see these sites by "MOSAIC" or "Magazine" view will make surf easier. Or type in the brand name of your device in the search box, and press "Enter".
Universal remote controls are available at most of the electronic spare part selling shops.
Sharp Aquos... | Answered on Jul 13, 2014
Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. It will be best to replace the inverter board as card basis.
Sharp Aquos... | Answered on Jun 12, 2014
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
Sharp Aquos... | Answered on Mar 01, 2014
Check its back-light inverter. Check the voltage that comes to it from the main power regulator board, and main digital board. To get some details, http://electronicshelponline.blogspot.com/Pull up older posts.
Sharp Aquos... | Answered on Dec 04, 2013
To do a factory reset, you have to enter its service mode option. If you wish to get more details about this, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sharp Aquos... | Answered on Oct 02, 2013
These blinks are fault indications. Count the number of blinks occurs at one time switch on, and check this link for details. The link contains the blinking codes to many brand TVs.
Sharp Aquos... | Answered on Jan 30, 2013
Though this could certainly be due to some defects inside, just try the following: Look for any loose contacts in power outlet. Try changing the input device to some other like a DVD player and see. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation.
Sharp Aquos... | Answered on Dec 23, 2012
Sometimes it will work and sometimes it will not work
Sharp Aquos... | Answered on Sep 02, 2012
please when I plug the TV the relay click continuously
Sharp Aquos... | Answered on Aug 31, 2012
Looks like a defect inside the TV. Ensure there are no loose contacts in power outlet and try changing the input device to some other and see. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation.
Sharp Aquos... | Answered on Aug 20, 2012
Sharp Aquos LC-C3234U 32 in. LCD TV Logo
79 questions posted
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Aquos Sharp
  • Aquos Sharp
Most Popular Question
no sound no picture no ruster no start
  • Televison & Video
