Check this link to download the user manual to this set. It has all details.
SOURCE: TV won't turn on
read from other forum. wouldn't hurt to try, unplug the power for 2 days and plug back in again to see if it will turn on.
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
SOURCE: sony kv27 s42 trinitron color tv
your tv has a problem inside..the supply that is going to the tube was been cut out... only the servicemen can do fixing your tv... there is a deefective parts...
SOURCE: blinking Sony Trinitron with no picture or sound
you have a drive ic problem. ic 600, r640 and modification needs to be performed. Take to a Sony servicer. Est.$150 parts and labor
SOURCE: timer button blinks but doesn't turn on
There are several faults that can cause this. Shorted diodes in the high voltage, a bad flyback transformer, a shorted CRT driver IC. None of them are very easy to fix.
