20 Most Recent
Sony FD Trinitron WEGA KV-27FV17 27" TV Questions & Answers
Sony Trinitron TV
read the answer on this page really helpfull
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Sony-Trinitron-KV-32V42.htm
1/31/2013 7:52:11 PM •
Sony FD...
Answered
on Jan 31, 2013
My Sony Trinitron WEGA KV-27FV17 comes on and
Hi
Thanks
for using FixYa. Two blinks are caused by over voltage protection; unit goes to
standby mode and then display the over voltage fault. Please check the power supply
unit for swollen/bulged capacitors and burnt wires/components on the power
supply board of your TV. You should try and turn off the TV for 8-10 hours to
reset it. Please make sure to turn off and unplug the TV
for at least 1 hour (this will drain off current from all components
especially capacitors) before you perform any repairs. Also note that the TV
consists of very high voltages even when it is in OFF condition. All this is
only recommended if you have electrical expertise and know how to
solder/re-solder components. Please do accept the solution if the issue is
resolved or else revert for further assistance.
Thanks
Rylee
4/2/2010 3:26:49 PM •
Sony FD...
Answered
on Apr 02, 2010
Buzzing sound wyen volume is high.
If you have a cable box on the TV, make sure the volume on the cable box is turned all the way up. If you do not have a cable box, some TV's seem to have a annoying buzz louder than others.
7/15/2009 1:18:53 AM •
Sony FD...
Answered
on Jul 15, 2009
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
