SOURCE: When I charge my Jazzy select 6 over night the off
I am assuming that the PWC runs and the batteries behave like there is a full charge. The performance of the Jazzy is good. If you have a volt meter you can check the voltage at the charging port but this is too difficult for the average user.
There is a battery display indicator (BDI) on the joystick that indicates battery charge through a series of LED lights. More lights, larger charge and higher voltage on the batteries. There are two reasons why the LEDs are not lit assuming the first two sentences are true:
1. The LEDs or the circuitry running them is burnt out.
2. The LED module has come unplugged from the circuitry.
The solution for both problems is the same. Open up the joystick case( if it is out of warranty )and inspect the LEDs and wiring. The easiest and most expensive way to solve the problem is to replace the joystick assembly. If you do nothing there is a good chance that you will get stuck somewhere because you do not know the charge state of the batteries. If it is under warranty your problems are solved. Call a qualified dealer in your area and have the problem component replaced.
Hope this helps.
SOURCE: How do you dial up the speed on the jazzy select 6
jrw if you are asking to increase the programmed speed of the chair then you need a programmer (a PP1) that will allow uo to increase the factory speed. But it's probably set at 100% already. Other than setting the speed on the joystick to full and changing the programmed speed will you be able to get the chair 's speed increased Hope this helps you
SOURCE: where on the jazzy select
Just found it our self. It was hidding under joystick (right armrest)
