Remove the handles. See if the chrome slip nuts holding the stems in are corroded. If they are, the cartridges may not be fully seated or the o -rings that seal around the cartridges may need to be replaced. If either of these is the case you can tell for sure by turning the stems to the on position with the handles removed and looking for water seeping around the cartridge. If none of the above is the cause then check to see if the aerator (screen on the spout) is loose or corroded sending a light spray back towards the faucet body that looks like a leak. If this is the case remove and clean the aerator, then reinstall it making sure not to cross thread it. If none of the above, replace the faucet. Be sure to call Delta first before replacing because they have a lifetime warranty and you just might get your faucet for free!
SOURCE: water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
SOURCE: Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
SOURCE: The faucet was leaking and nut wouldn't come off
There are several tools you can use to remove stripped nuts and bolts, here are pics of two different types. You might also want to try using a good set of chanel lock pipe wrench or vice grips
This is a common problem, and often times it is impossible to remove the nut without damaging/destroying the faucet.
You may also want to invest in a basin wrench. It will make removal and installetion MUCH easier.
This is a basin wrench.
You are wise to go with Moen. They make a great product, offer lifetime warranties and have great customer service.
Testimonial: "Thanks for your advice and the picts!"
SOURCE: goose neck kitchen faucet is leaking around the
yes a common fault need to replace o ring can diy it yourself
SOURCE: I think our Signature faucet
these are really well designed.take a flashlight and go under and look up.most leaks come from stop valves.if the hose is leaking,you can change o rings.oooooor you might have a bad hose.delta will be happy to replace it. I've found there customer service easy to deal with.
