SOURCE: U-Line no longer cooling
This sounds like the thermostat is the problem. I wouldsuggest touching the compressor at the back of the unit to see if it is hot or cold. If it is hot then you have probably have power down to the compressor, if it is cold you could (if capable) bypass the thermostat to see if it kicks in. Hope this helps.
SOURCE: unit not working
could be a thermostat problem, check the thermostat for continuity. it should have, if not, then replace the thermostat.
tnx 4 using fixya,
drcool
SOURCE: I have a u line
If compressor is running then unit has a sealed system issue- throw it away unless still under wty. If comp not running then probably bad relay on it. Only way to check is to replace relay. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
SOURCE: Uline ice maker
The trough gets refilled on each ice cycle, if it's circulating, then the water supply is adequate.Y
The exact model would be helpful, but you could call 1-800-779-2547 U-Line's tech line
or email [email protected] for help
http://www.U-Lineservice.com
SOURCE: Uline 15RBK not cooling
hi!! make sure that the inside evaporator fan is on and that the compressor and condensor fan motor is on. if they are all on then you have a seal system leak of refrigerant..Good luck..
