I WAS WATCHING TV AND I HEARD A CLICK AND THE TV WENT BLANK (BLACK SCREEN). THEN SEEN THE RED LIGHT FLASHING. IT WOULD FLASH 10 TIMES THEN PAUSE.
Check its fan SOS board for fault. Visit this site for more details. Pull up older posts. Blinking codes to Panasonic Plasmas are given in detail.
SOURCE: Philips 42 in. Plasma shut down
Thank god we purchases the ADVANCED extended warrenty. This tv has been nothing but problems.
Fuzzy picture, picture shutting off after 20 sec coming back on and now blog of colors shut off never to come on again. 7 blinking red lights on the front. Waiting for the repair man again.......
SOURCE: Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
[email protected]
SOURCE: 42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
SOURCE: red light flashes 10 times - Panasonic TH-42PX6U
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
my hd tv is a panasonic plasma TC-P50C2
