The digital RCA audio cable is not the same as the analog RCA audio cable. You need a digital audio (input) to analog audio (output) converter. Amazon has a number of models: https://www.amazon.com/DA-Converters/b?ie=UTF8&node=3224445011 . Many models do not come with audio cables. Thus you'll need to supply the digital coaxial audio cable (see https://www.amazon.com/AmazonBasics-Digital-Audio-Compatible-Coaxial/dp/B01D5H8TS4/ref=pd_bxgy_2/134-6585034-3648633?_encoding=UTF8&pd_rd_i=B01D5H8TS4&pd_rd_r=e311c756-6e80-4fd0-8026-16a144c6b41d&pd_rd_w=r0LwZ&pd_rd_wg=4jYy9&pf_rd_p=f325d01c-4658-4593-be83-3e12ca663f0e&pf_rd_r=YVE00Y31KS8TJ3YENVFN&psc=1&refRID=YVE00Y31KS8TJ3YENVFN for one version) and the RCA analog audio cable.
I hope this helps. If your TV has analog audio outputs (2 RCA or headphone jack), you may be able to avoid the converter. Connect the HDMI cable from the BDP-S1700 to the TV, then connect your TV audio out to the Onkyo TX8511. Use either an RCA analog audio cable or a Y-cable (3.5 mm to 2 analog RCA), Set the TV to external speakers if you need to. (Some headphone jacks automatically disable the TV speakers when in use.) You may need to adjust the video to audio sync with this method. Check your TV and Onkyo manuals.
The Sony STR-D311 only has analog audio inputs. If your TV has an analog audio output, use the appropriate RCA cable (2 M/M plugs on each end, usually red and white). If your TV has a headphone jack, use a 3.5 mm to RCA adapter. However, if your TV only has digital audio outputs, you will need a digital to analog audio converter, like this: https://www.amazon.com/Digital-Optical-Analog-audio-converter/dp/B004C4WPXA . You will also need the appropriate analog audio and digital audio cables.
The whole USA (years ago now) converted to digital TV signal format from analog (which is what your TV uses), this means that the TV will not pick up any channels without a digital to analog converter box, you can buy them very cheap on eBay.
According to the user's manual, the TV can receive and decode analog and digital TV signals, so no, you should not need a digital converter box. During the channel scan it will search for analog channels first, then digital ones.
That's a CRT... it's inherently analog. If you use the right equip, you could get a digital signal to display on it, but the picture would still be analog.
This TV is analog, meaning there are no "straight digital" inputs, and the tuner itself is NTSC (analog), and not ATSC (digital). You will need a digital converter box to receive over-the-air (broadcast) digital television stations. This does NOT, however, preclude you from purchasing Digital Cable or Digital Satellite, and using the analog output on their converter boxes. The television will display high-definition images from those boxes and other sources.
I have the owner's manual in .pdf (adobe acrobat) format. Leave me your email address and I'll send it to you.
the tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Model has one NTSC RF and two NTSC composite inputs. It's compatible with analog Over The Air and non-scrambled analog cable broadcasts. After the US analog cutoff (currently scheduled for June 12) it WILL require a digital to analog converter to receive ATSC digital TV transmisions.
