SOURCE: adjust rear hand brake on Mongoose 20 inch bicycle
Here is the perfect site for you:http://www.bikeguide.org/how-to/brakes/brakes.php They're called gyro brakes by the way.
SOURCE: I need the owners manual for a Mongoose Hoop D
Try here:http://www.mongoose.com/usa/eng/bmx/man_inst Most of their manuals are generic. If you have a specific question such as how to set up the brakes, I'll try to help out.
SOURCE: Greeting I just purchased a Mongoose Blackcomb All
Unhinge the Vbrake at the front, by ushing the arms together and sliding the silver metal pipe out of it's holder. The brkes should release their tension. Undo the front bolt going through the center of the wheel with two spanners.
Don't use one spanner as it turns the opposite side and you'll be there all day.
Lift the bike up and pull the front wheel out away from the forks.
Vote for me if you think this helps you. Thanks :)
SOURCE: I have a Mongoose Dual
It's prabably easier to buy a whole new hub. And for ablout another $20 you get a whole new tire. You should do that. Have a bike shop do it because it can be tricky.
SOURCE: Need a manual for a
A simple search engine query finds it.
Manuals are generic. Try http://www.mongoose.com/usa/usaeng/mtn/man_inst
