SOURCE: Sunfire power chair won't charge but lights up when plugged in
you need to have the batteries tested it is possible that if left in a discharged state for an extended time that thee batteries may be damaged and will not be able to be recharged
SOURCE: Chair has new bateries but barely will crawl when
Contact your retailer and explain this to them. They are in the best position to help you with this matter.
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
SOURCE: flashing lights and chair does't run
Sounds like it's locked. Try this: Controller Locking Instructions
SOURCE: lights scroll from lt to rt ant lights around joy
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
