I have a Bernina Activa Patchwork Edition 140. Does it have "needle stop down" capability? (I can't find any button, and it's not shown on the screen.) If not, can I manually place the needle down (by turning the wheel) without damaging the machine? I have to do some tight curves in a satin stitch, which means I'll have to lift the presser foot and rotate the piece around the needle pretty frequently.
The Bernina Patchwork 140 does not do embroidery from a file (either built-in or external). You can do some free-hand embroidery by lowering the feed dogs. Depress the feed dog position button on the right hand side of the machine. It's below the balance dial and between the foot control socket and the power cord socket.
I hope this helps. ManualsLib has the manual for the Bernina 140; it's a shared manual with the Activa 130 and 131.
As far as I know, the Patchwork 140 doesn't have a needle stop up/down button. You'll need to use the hand wheel to bring the needle up or down, as needed. The Bernina machines that have a needle stop up/down button have this button below the LCD screen. (On those machines, it's usually the left-most button below the LCD.) I suspect the index giving a page number for the Needle Stop Up/Down button is a artifact of using the same index for multiple machines.
The foot control you are talking about will activate the needle down function on your machine. You need to press down on your heel on the foot control. This was the precursor to the automatic needle up/down option that is found on newer sewing machines that will automatically stop with the needle in the down position.
If you don't see a button that you can select for needle up / down, then you can't. Your foot control might might have a symbol at the lower side that shows and up / down arrow. If so you can tap the bottom edge of the foot control and the machine will half cycle, stopping with the needle in the down position.
Some machines will not do any of their automatic forwards and backwards movement type stitches in reverse, are you trying to reverse in straight stitch or a more complex stitch.
The Activa is a late model quality machine, do you have a Bernina dealer locally you could ring up and ask or take it to?
