I can't quite see how to remove the back of my Sekonda 3100 watch. I need to replace the battery.
Here is some videos that may help you
Testimonial: "Thanks! I'll keep fiddling with my knife then! "
Do not use a sharp object to open the back of the watch. Some watches need a blunt blade to open them, others need a spanner specially made for the grooves on the back of the watch to unscrew it. Then to close them it is not a case of clipping it closed. To close it properly you need a press. This press, presses the back of the watch on properly and with no dents in it. Any dents in the back of the watch will make it harder to reopen the watch again. If the battery is held in with screws then rather take it to a proper person to do this because if they are not replaced properly then your watch won't work. I hope this helps!!!
SOURCE: how do i remove the back on my sekonda mens watch
mcdevito75 here, Generally thr back is simply pryed off useing a sharp knife (steak) or with a case opener, or at times the back is screwed on, little square holes around the back of the watch require a special tool, or there may be 4 screws holding down the back to the case, even if you get the back off you may need Jewelers screwdrivers to remove / replace the battery. BEST BET, look for a small watch repair shop in your area.
SOURCE: how to remove the back
You need a special spanner wrench to hook into notches in the back cover.Depress snugly and rotate counterclock wise to remove. You can purchase this wrench at some jewerly stores or if you are just needing to change your battery pay them to do it for you. Thank you.
