There is a switch on the back of most machines behind the feed dogs that allow you to drop the feet for embroidery, you have to switch it back to raise the feed dogs back up
Not knowing this exact model or your history with this specific machine, I'll just toss out the following info.
If feeder dogs are not stepping, none of the following applies to your problem. Otherwise;
I believe the 1425 does not have dog up/down selection, therefor it uses stitch length zero (or about) to keep the feeder dogs below the needle plate when embroidery/darning.
Assuming feed dogs are stepping (rotary reciprocation), adjust stitch length toward a longer setting. Eventually this should raise the height of the feed dog step to a point above the needle plate thereby feeding the fabric.
So if choosing a longer stitch length feeds fabric, either the feed dog height needs adjusted, or something else has caused feed dogs to be lower than normal (additional repairs).
check where the direction button/lever is
it controls the feed mechanism and if it is in the middle the teeth will just go up and down
set it one way and it moves forward and set the other way will go in reverse
it is graduated to provide a stitch length ( number of stitches per 1")
What Viking is it ? Have you cleaned between the feeders? If all is clean, try this test. Remove needle. Turn hand wheel so that feeders are up. Put fabric in machine. Lower presser foot. Make sure presser foot pressure is set at normal. Try pulling the fabric towards the front of the machine. It should be hard to pull. If it is easy to pull you need new feeders. They are worn down.
ck presser foot tension. even with sightest presser ft tension goods should feed. next ck that your feeder plate is not loose or broken. take off the plate and see if u can move the feeders with your finger. tighten screws makinf sure the needle is centered inthe feeder plate hole. if this is not the problen then youe=r feeder plate teeth are too low or worn out. look up how to raise the feeders. the should be 1/8" above plate.
run you finger over the feed dogs under the foot - can us feel them above the surround? if not, you have placed your machine into free style sewing, and the feed dog does not advance the fabric in this mode. Look in your manual and see where the feed dog gets lowered/raised - raising it again should solve your problem.
Presser foot tension is to low for the weight/finish of the fabric, or bottom dogs are worn.
The feed dog feeds the fabric under the presser foot while you guide the fabric.
The feed dog regulates the stitch length by how much fabric passes under the presser foot as the machine stitches.
It is important for you to not push and pull the fabric under the presser foot. Allow the feed dog to move the fabric, so that you do not bend and break sewing machine needles.
the feed dogs in the needle plate area are what moves the fabric while the presser foot hold the fabric
if the feed dogs are not up, check to see what position are in,,they should be in the bobbin area
if you can't move them they should be checked at a repair shop
You can also check the pressure foot regulator (near were the light is open the cover as if you were threading neelde and it is in there its mealat and has numbers 0-3 on it. 1 is for heavy fabrics, 2 for med, 3 is for light and 0 is for darning or fre motion sewing. the standard setting is 2. try both this and the feed daos, one of them should work.
