Has rolling lines on screen
SOURCE: 65 in mitsubishi hd projection with rolling and wavy lines
Hey guys the problem is a 3 pin 9 volt regulator
SOURCE: blue and red overlap shadowing
ok I have tried to converge the colors many times and even rested the convergance to factory settings and the problem still keeps happening what else could i do?
SOURCE: Mitsubishi Diamond model WS-65813 The system
After plugging the TV in, it normally takes about two minutes for the processor to boot before the light will stop blinking and the TV will turn on.
The power supply will need to be replaced.
SOURCE: i have a Mitsubishi WS-65869 65 in. Rear
If you see separation of colors (red, green) in this wavey line most likely you have problem with convergence circuit. Two convergence amps have to be replaced. They located in a middle of the TV boards attached to big aluminum radiator and they part number starts with letters "STK".
I would recommend to let professional with this repair. Should cost you about $250-$300.
Regards.
Russ.
Testimonial: "thanks, can i send you an email with a picture of my screen? this might explain more than i did. let me know. thanks"
