Casio G-Shock GW500A-1V Wrist Watch Logo
Posted on Mar 02, 2013
To adjust the analog time for ga-110hc-1a - Casio G-Shock GW500A-1V Wrist Watch
NavigatorX
Level 1:
New Friend:
  • Contributor 65 Answers
  • Posted on Jan 28, 2014
NavigatorX
Contributor
Level 1:
New Friend:
Answers
65
Questions
Helped
62085
Points
85
Analog time follows digital time.Correctly set your local time and analog time will come up correctly as well.If not, try to run the hands alignment procedure (H-SET) following manual instructions.
1 Related Answer
kalamazoo222
Rick Hurd
  • 285 Answers
  • Posted on Mar 01, 2011
SOURCE: Can't set the analog time
Go to the Casio website here:
http://world.casio.com/wat/download/en/manual/
Enter the 4 digit code that is on the back of your watch, and the instructions will appear.
2answers
How to adjust hands with anolog time
pull the adjuster knob out and wind it around to move the hands
push back in when the time set is right
1helpful
Alarm off
- Keep on pressing mode button on watch till alarm mode appears.
- to verify alarm mode check out the time alarm rings and match it with the display while selecting the mode.
- press adjust button to disable
- or press two buttons on right of watch to adjust the alarm
I bought this watch in May of last year. For the last 3 months, every 2 to 3 weeks I have to reset the hand home position. Once that is done, I have to then reset the home city and time manually. What...
Hand home positioning normally has nothing to do with time setting.
Just set your local time and date and then you can do the hand home positioning procedure.This will not affect the time setting.If hands,after a while,do not show correctly,this means that the watch is under severe magnetic field, after severe shock or finally watch malfunction.
You must know that on this type of watches analog time follows digital time.
Restore to factory settings
take the back off the watch then do this
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs
Sync time in gshock GA110-1A
Simple straight forward instructions in youtube video below:
https://youtu.be/R84_g7Wrw4E
1helpful
2answers
How do i set the anolog time
Go to "setup" pushing mode sometimes then right down push should move analog clock
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
