Toshiba DKT3010SD Corded Phone Logo
Anonymous Posted on Feb 19, 2009
Toshiba DKT3010 w/voicemail, how do I change message?
I don't recall how I accessed the voicemail to change the greeting.
Anonymous
Level 1:
New Friend:
  • Contributor 45 Answers
  • Posted on Feb 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
45
Questions
Helped
16172
Points
86
Usually technicians setup the pilot number to voicemails as extension 555 or 850. If you dial one of these extension and voicemail picks up press *. Your user ID will be your extension and your password should be your extension plus 997. Once in voicemail follow voice driven menu.
I need to change the greeting of Iphone 3. Where to go?
I'm assuming you mean the voicemail greeting message.
iPhone 3GS How to Change Your Voicemail Greeting GROK Knowledge Base
This article should help. Has step by step instructions on how to change your voicemail greeting on your iPhone 3.
How to Record Voicemail Greeting for Your iPhone
Here's another step by step guide.
Hope this helps!
How do I change my outgoing voicemail message?
Depending on your wireless service provider, the method for changing your voice mail greeting or voice mail password might differ. You should be able to access the options for changing your voice mail greeting or voice mail password when you check your voice mail. For more information, contact your wireless service provider.
Voicemail change message
How To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
How To Record Your Alternate Greeting (Used when on vacation or out of the office.:1. Press the Check Voicemail key or press the Feature button, then 981
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the Choose softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting.
3helpful
2answers
Setting up your voicemail
I bought and Uniden Dect 6.0 phone and the other day I had a voicemail msg but I can't retreive it how can I do that the book doesn't show how to set up for voicemail
Voicemail
Call your cell phone number (from any phone) and press * key while your current message is playing.
You will then be prompted to enter your password followed by the # key.
From there you should press 3 to access your greeting.
Press 2 to re-record your greeting.
Hope that helps,
1helpful
How do I change voice mail message?
-Dial into voicemail
-Enter password to access system
-Press button for Greetings or Administrative Options menu
-Choose type of greeting
-Press button to change it and record new greeting
-Listen to new greeting and press button to confirm
-Exit system
May 02, 2008 • Cell Phones
20helpful
3answers
Would like to change voicemail message in phone
-Exit system
Voicemail reset
Norstar Common Voicemail Features To Check Your Voicemail:
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
10. Press the ChOOSE softkey
took this from a guide i found, helped me out
2answers
Resetting company voicemail
4. Leave message
took this from a guide i have, might help you guys out
Top Toshiba Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
