My craftsman door will not open it will not open manually when you release motor it does not disconnect and the plastic piece by the arm looks like a pin is missing. and in the track a small black piece travels up and down the track without the arm.
It sounds like that missing pin is your problem, the trolley attached to the arm with the pin. Its hard to diagnose, but call in a Door Opener guy and he can probably fix it in a few seconds for free. Otherwise, try and find the pin or something like it to fix the arm in place and see if you can MANUALLY operate the door that way. BTW, Disconnect from power before you try and experiment.
