To get to the network settings: Press the Utility/Counter key, select Administrator Settings, enter 12345678 as the password, then select network settings. You will find all the settings for networking the machine there. The print drivers can be downloaded from Konica's web site: kmbs.konicaminolta.us
User manuals can be found there as well.
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Verify the fusing unit components (heater lamp,thermistor) and the rear contact Switch located under rear cover when you closed the fusing unit right cover door.
It appears that you can find the drivers here. Just scroll down to the bizhub 180 box, and the Win 7 drivers should be right on top. It also appears that they have included the bizhub 162, 162f, 180, and 210 in the download. Hope this helps.
I Have a Konika Minolta bizhub 211. I had been trying this solution for repairing m2 call. but the code is appear till now. anyone help me. please give me solution step by step. Thanks
konicaminolta.com.au.....look for service and support...and
explore...
