I've had to shut off the water line to my refrigerator, because it was running without stopping, and coming out under the fridge - my kitchen is flooded! The ice maker appeared normal, everything looked fine inside, nothing leaking down the backside. It's a KitchenAid Superba manufactured 11/00. Model # KSRS25FGBL04, Ser. SK4530173. A few years ago, the vents got clogged with dirt and pet hair - could use another cleaning now, once I get the water dried up. Could that be related? Thanks.
WhirlpoolET21CKXHWOO--Water keeps leaking from freezer down to below bottom crispers, please help
Hi, if the only way you could stop the water was to turn it off at the water source, you need to change the water inlet valve. Make sure you check the water fill line for any leaks before you change the valve.
If I canassist you in getting the vavle, please let me know.
Thanks
Vic
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
