I need to know where the colored wires go to repair this.
You can see if the wire is made corresponding to the USB 1.x/2.0 standard. (All USB cables should follow the standard, but many manufacturers don't respect this and use whatever cables they get cheap.)
The Pin-out and wire colors can be found here:
USB Wikipedia the free encyclopedia
(scroll down to "Pinouts", also provided below)
USB 1.x/2.0 standard pinout
1 VBUS Red (or orange) +5V
2 White (or gold) Data?
3 Green Data+
4 GNDBlack (or blue) Ground
Hope this helps!
SOURCE: I have have the Microsoft
Try going to control panel and clicking your input and speaker settings.
SOURCE: Headset isn't recognized by computer and audio doesn't go through headset
With the infamous Vista, try:
Start --> Control panel --> Hardware and sound --> Sound --> Audio devices admin [I have a Spanish OS, I hope it is the same in the English version], then assign as default device the headset.
With Skype and other sw, you have to specifically pick the lx-3000 as the device that will be used as audio device (and the same has to be done to use the mic).
Pretty cumbersome....
SOURCE: how do i connect the Microsoft LX-3000 Lifechat headphon to x box
hi
how do i connect the Microsoft LX-3000 Lifechat headphone to x box 360, i
plugged the usb into the front of the x-box and its not working , i,ve
got no drivers, but i can down load them , but what do i do with the
drivers then?
SOURCE: i need to downlaod a
you can download the correct drivers here: http://www.microsoft.com/hardware/download/download.aspx?category=ICE&type=LifeChat&sku=JUG-00001
good luck!
SOURCE: Have Windows XP and Lifechat
Hey! If you try to install this does it work properly?
http://download.microsoft.com/download/F/7/0/F70FBF72-2AAB-4D60-9E49-7B015E8E5851/LifeChat1_4.exe
Otherwise did it come with an installation cd?
