SOURCE: water shut off sticks open
Make sure that the float in not touching the side of the bowl. You may oil the hinge on the float. Lastly you may turn off the water , open the valve and see if any of the internal parts are swollen or enlarged interfering with the final rising of the float, and closing of the valve.
SOURCE: American Standard toilet constantly runs
The rubber cork thst lifts when you press the handle is leaking by and causes the water level to drop below shut off level so it trys to maintain the the shut off level every minute or so. Replace the cork with one made with the red rubber. good luck
SOURCE: American Standard Carlyle. I think this is the
u will probly get a diagram with the pack u buy if u bay new sistern parts ,but its not that hard. pay atension to detail whan u disesenbel it. mostly to the rubbers and if u do have a leak use silicone. most rubers will be 1 inside 1 outside with washer holding it tight. sould be a breez bt if u are having any probs let me know im a proper plumber. wil coutch u threw. plz give me a reating. started using fixya tonight and if my advice helps ur rating wil help me help more ppl thx. o and if there is not a diegram in packet thast ask hardwear store to give u 1 or to exsplian. just gone on internet. they dont have 1 i can post to u sory. bt try and ill help u if u have a problem
SOURCE: American Standard Cadet 3 - bowl water slowly drains
ok, I read through all the web sites and solutions for the Cadet3 bowl loosing all the water after 3-5 minutes of being flushed. After installing my own, I figured I didn't get a good seal with the wax ring, I must have misaligned it. So, I went out and bought a new wax ring, picked up the toilet, cleaned everything up and made absolutely sure it was seated right. No Joy, same thing the toilet bowl would loose all of it's water regardless of the tank adjustements. My vents were not clogged. so, about the time I am ready to take the toilet back I tried flushing one more time and water wouldn't go down so I plunged it several times and what ya know the toilet works normally now and retains water at the right level. While I am no expert, it appears to me that since there wasn't anything ever put in the toilet except for 2 small pieces of toilet paper that maybe part of the huge wax ring that came with it partially clogged the toilet causing a siphening effect? How else would the water level seep way down below the bottom of the top portion of the trap built into the toilet bowl (unless the toliet was defective)? So, it may not be your prroblem but before replacing the toilet, I would recommend a long hearty plung if your toilet bowl won't hold it's water.
