Stick in slot 2 only works fine , matched pair in 3 & 4 , computer wont post , sticks in 2,3 &4 computer goes into repair boot mode and just keeps running , never fixes the problem . Do I have a fried board or is it possible the bios is the problem ?
SOURCE: motherboard
Here is what you need to do. Disconect the module with the usb ports from the motherboard. It took a while for me to figure it out but a damaged usb port will make the computer go nuts.
SOURCE: motherboard
One of the greatest factor in intermittent shutdowns is because of heat issues. try to check the fans if they are all spinning. if all fan's are ok then you only need to replace the motherboard. here's a manual that might come in handy http://support.dell.com/support/edocs/systems/dim5100/en/sm/index.htm
Hope this helps.
thanks
SOURCE: Memory Upgrade Attempt Causes Computer Not to Post
Seeing as the message is indicating a problem at one of the timer checkpoints, fatal is probably an accurate description. You are most likely looking at a motherboard replacement scenario. I've seen improperly seated memory modules toast timer circuitry on old boards back in the days when most of the timing circuitry was constructed from discrete components, not entirely IC-based timing solutions, but I have never seen it happen on modern boards.
SOURCE: computer will not boot numbers on fron of computer
the lights denote that is has encountered a system failure, very vague to be exact. try running the hard drive diagnostic if possible. it could also mean a hardware problem, worst case scenario would be a mobo failure..
Hope it helps!
SOURCE: can I install one (1-gig) memory stick instead of ...
Yes.
The Maximum Total Amount of Ram Memory is 2GB.
(2048MB)
The Maximum Amount for EACH ram slot is 1GB.
(1024MB)
Ram should be installed in Slot 1, when using just one stick of ram.
This is the ram slot closest to the Processor.
The Processor reads ram memory that is installed in Slot 1, first.
This is Dell Support, and the main support page for the Dimension 3000 desktop computer,
http://support.dell.com/support/edocs/systems/dim3000/en/SM/index.htm
In the list left-click on - Technical Overview
Now click on - System Board Components
Number 1 is Slot 1.
Note*
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate computer hardware components inside a computer.
Work on a table.
After you have opened the computer case, and BEFORE you remove that ram module from it's anti-static protective bag, TOUCH the metal frame of the open computer case. (Power unplugged from computer)
This will relieve your body of static.
Ignore the above if you are already aware.
