Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=3468#ov
A new hdmi connector, can be ordered by a gigabyte dealer.
But changing the connector, is not a do it your self job.
I suggest you to buy a graphic card, to add on the mainboard in the
1 x PCI Express x16 (orange slot) for better performance.
A new graphic card, does also have the hdmi connector
This will be the cheapest way to repair it.
Good luck
Testimonial: "Thanks. That sounds like it will work. I will let you know. RW"
SOURCE: Gigabyte GA 81845 GVM 775 Soundcard drivers
Hi try this link:-
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1930
It has all the drivers you need for your motherboard.
Hope this helps.
SOURCE: motherboard GA-8I86GME-775-RH
Leon, this may be the sight you wanted.
If you were searching for the drivers (googling etc) you may not have found them as your model number of the mobo was missing a number.
try here:
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=2274
Keep us informed if this was what you were after or not.
**.The best way to acknowledge contribution is to rate it's relevance.**
Type: Dual Channel DDR 400/333 Mhz
Max capacity: 4 GB
DIMM slots: 4
Use Socket 775 processors:
Supports LGA775 Intel® 90nm Pentium® 4 processor FSB800 with HT technology
SOURCE: I WANT DRIVER FOR GA-TG33MH MOTHERBOARD..INTEL 775
you can serch in google. also www.driverstock.com can help u thanks.(nepal}
SOURCE: GA-8I865GME-775-RH (rev. 1.x) for this gigabyte
You will just go their website, type the model no along with socket pin and hit in search.
Then you can find, download option and choice the OS from drop down box.
Just click on bellow the link
http://www2010.gigabyte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2358
Also you can click on mother board under support and series >model > socket
http://www2010.gigabyte.com/Support/Motherboard/Driver_List.aspx
Happy new year
Hope it will help you.
The HDMI plug or socket integrated in board got mangled. ??? is it possible to replace the plug or just replace board????
