SOURCE: want to know how to remove the flush alve on a one
Open the rear lid of water closet. on the very inside rear of the flush valve there is a very then nut it unscrews in the clockwise rather then counterclockwise. I think that was the problem
SOURCE: flush valve
it is all one piece,replace it with the same model. a plumbing supply house is the only place you will find what you need.
SOURCE: Eljer Canterbury one piece remove flush valve
I had the same problem and contacted Eljer and they sent me the above instructions to make a tool to remove the flush valve.
SOURCE: I have to hold the lever of my Eljer one-piece
I have this eljer toilet one piece that had this problem after i changed the fill valve. i changed the flapper with a red one with a slider adjustment. It will slow the flapper from closing to soon. Leave some slack on the chain. i had to play around with the tank water levels. I now have a complete flush without holding lever down. good luck!
