20 Most Recent Eljer Toilet Onepiece Canterbury 081162047 Questions & Answers
I wrote a tip that might apply to your situation:
https://www.fixya.com/support/r6633961-toilet_doesnt_flush_water_just_spins
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Eljer Toilet ... | Answered on May 07, 2019
Probably a small blockage. Plunge the toilet until it flushes quietly. That, or you need more water in tge tank. You'll have to adjust the water flow. I'd say you have a small blockage though...
Eljer Toilet ... | Answered on Feb 02, 2015
The problem is the flapper closing too soon or too late to get the best flush. There are several brands out there that are adjustable. I agree about finding another plumber if he can't fix this, but you should consider buying a new low flow toilet. There are a few brands that have a "Power Flush" tank which uses a pressurized bladder inside the tank to flush the toilet consistently and completely every time. Another upside is the water savings (1.6 gallons versus 4-6 gallons).
Eljer Toilet ... | Answered on Nov 07, 2014
There is a large slotted screw in the center of the flush valve. Use the biggest straight bladed screwdriver you have with nice sharp edges to loosen if not remove screw. Once you get it loose at least you will be able to tilt it out at an angle. that's how I got mine out. now all I have to do is find a new one!!!
Eljer Toilet ... | Answered on Jul 23, 2014
I had the same problem and contacted Eljer and they sent me the above instructions to make a tool to remove the flush valve.
Eljer Toilet ... | Answered on May 25, 2013
Did you ever find the answer to your problem? If so please share..
Mine is doing the same thing. I have figured out where the leak is, but not why. The water level in the tank is too high and so it is running out the rim wash. When enough runs out there will be a phantom flush, the tank will again be (too) full, and the whole process starts again. I have all new fill valve, cup and counterweight with tank fill and rim wash tubes, and even the float assembly. I have adjusted every way I know without success. Any help anyone? Please? And, I might mention that I had success for some years with one of the general fills sold at the box store, but the 2nd one I bought did not work, so I paid nearly $100 to buy "will fit" replacement parts that came with NO directions. :(
Eljer Toilet ... | Answered on Feb 18, 2012
The flush megnisems rubber has parished.
Step1. open sistern and locate the flush meganisem, [shoold 90% of time be the gajet in middel]
Step2.unhook or unscrew all the handels conected to it,
Step3. turn the meganisem left, it wil pop out and at the bottom after you pop it out u see a black rubber that looks damaged, go to plumbing shop with the rubber and they will give u 1 ,its cheeep.
that should fix it.
plz rate my advice
Eljer Toilet ... | Answered on Nov 21, 2011
Look under the stool for the water valve coming out of the wall and turn it clockwise till it stops turning. This will turn the water off. Flush the stool and get all the water out of the tank as possible.
Look where the water hose goes to the bottom of the stool tank. You will have to take the hose loose with a pair off big water pump pliers or crescent wrench.
After taking the hose loose from the stool, there will be a big nut just above where you took the hose off the tank. You will have to look under the tank to see this nut. Use the same wrench to take this nut loose. You may have to hold on to the old valve.
Once you get this nut off, the valve will be loose from the tank, and you will have a little water leak out of the tank which you can catch with a big towel.
You should be home free from here. Put the new one back in reverse order.
Eljer Toilet ... | Answered on May 12, 2011
Make sure the flush valve is closing properly and that the water level is not set too high causing water to enter the overflow tube. If the flapper seat is damaged and cannot just be be cleaned, you can add a new seat right over the old one. Fluidmaster sells them for just a few dollars. Most hardware stores have them - Home Depot and Lowes stock them.
Eljer Toilet ... | Answered on Feb 27, 2011
The toilet tank valve needs adjusting for a lower water level in the tank; or the valve is faulty and needs replacing. I can't tell you how to adjust it without knowing what type you have. Many of them have a screw in the very top which when turned will change the tank water level at which the valve shuts off the water.
Charlie
Eljer Toilet ... | Answered on Feb 23, 2011
You need a heavy-bodies substance to fill the hole.
I have no idea if you can make this repair titanic-proof against leaks
Putty-stick-type epoxy from hardware or home center: Knead two parts together and apply in as many applications needed until hole is filled.
Auto-body filler? Fiberglass? Shoe goo? Ordinary caulk? Silicone caulk? Construction adhesive.
Nothing is going to be waterproof, so if a flood is likely, I would buy replacement product.
Eljer Toilet ... | Answered on Feb 02, 2011
Eljer Toilet  Onepiece  Canterbury  081162047 Logo
80 questions posted
Top Eljer Home Experts
john h
US Parts Center
US Parts Center
Mike
Are you an Eljer Home Expert? Answer questions, earn points and help others
View Most Popular
Eljer Home
  • Eljer Home
Most Popular Question
occasionally after flushing water
  • Home
