So I was at school today messing with my iPod(4th generation Classic), when suddenly, I press the center button, and the device does not react. As if I never pressed the button in the first place! I try pressing Menu, Fast Forward, Rewind, and Play/pause, and it will not respond. The touch part still works. When I put it on my iHome and use the remote, I can change bands and songs, but when I press the buttons on the actual device itself, nothing!
I noticed that a few days earlier, I had to push the buttons down a litte harder to get it to work. Now, today, it just stopped. Period.
Please help. My parents are pissed at me, saying it's somehow my fault!
Hi!
Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step until apple logo appears.
If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset your iPod
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
iPod not responding
If your iPod does not respond to these steps, see additional steps in the "iPod troubleshooting basics and service FAQ".
Additional Information
Apple releases new versions of the iPod Software Update application from time to time. These later versions may include new functions or improvements to existing features. Learn about updating iPod's software.
To return iPod to its original factory settings, use the iPod Software Updater utility to restore iPod.
IPods are noted for their ease and portability, which is what makes them such a popular item. No matter how wonderful an electronic item is, there may come a time when it needs to be reset, and a 4th generation iPod is no exception.
There are situations when an iPod may freeze up such as when it is disconnected from the computer without being properly ejected in iTunes first.
A reset is not as extensive as a restore, so you will not lose any data that is already on the device.
Resetting the iPod is a very simple process that takes only seconds to complete.
Make sure the "Hold" switch is in the off position.
The "Hold" switch is on the top left of your iPod casing.
Move the "Hold" switch to "On" and then immediately back to "Off."
Press and hold the round button in the center of the click wheel and at the same time press and hold the "Play" button.
Hold both buttons down for 6 to 10 seconds or until the "Apple" logo appears on the screen.
Stop holding the center button and the "Play" button. Your iPod Nano 4th generation has now been reset.
hope this helps
Thank you so much! Your first suggestions didn't work, because the Menu and Play buttons were out of sync. But when I restored default functions by plugging it into the computer, it worked again!
Thanks!
