1995 Dodge Dakota Logo
tone Posted on Jan 26, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix code 41 on a 1995 dodge dakota
My dodge runs for 5 min. then shouts off and is geting 41 code
Mike Butler
Level 3:
  • Dodge Master 6,674 Answers
  • Posted on Jan 27, 2013
Mike Butler
Dodge Master
Level 3:
Answers
6674
Questions
10
Helped
2895118
Points
19845
5 Related Answers
Anonymous
  • 1201 Answers
  • Posted on Aug 17, 2009
SOURCE: 1992 Dodge Dakota 3.9 liter 5 speed manual
75W/90 gear oil.
Anonymous
  • 1392 Answers
  • Posted on Jul 25, 2009
SOURCE: 2002 dodge dakota v6 3.9L starts but stalls immediatley
Sounds like your IAC motor is getting stopped up. Clean out the passage, and the throttle body. If that doesn't work, get a new IAC motor.
Anonymous
  • 5 Answers
  • Posted on Jun 06, 2010
SOURCE: 1988 Dodge Dakota brake line size question
they should be 3/16" but if you want to be sure, take a quarter inch wrench and put the open end over the line if it is sloppy on the line it is 3/16" , if it fits nicely, it is 1/4" . that is the only two sizes they could of used.
kapishtech
raj somaiya
  • 2272 Answers
  • Posted on Oct 14, 2010
SOURCE: what is 3 5 5
The error code 355 is related to coil problem. 355 means Coil wire number 5 is not reaching peak current at the right time.The ignition coil has to be removed and checked.The connection between spark plug wire and coil needs to be checked. ------------ Keep updated if any more queries.Thanks.
Anonymous
  • 210 Answers
  • Posted on Jan 28, 2011
SOURCE: I have a1987 dodge dakota 3.9v6 having trouble
hi hope this helps
when you pull the starter forward lift the back of the starter up.
sometimes you'll have to also disconnect the steering shaft coupling from the steering gear
and slide the shaft out of the way
hope this help give feed back
I have a 1995 Dodge Dakota Sport two-wheel drive 3.9 it is thrown codes that is 32 5 5. Can you help me with this anyone?
Question moved to model category.
So the code is '32 5 5', or is it 32 AND 55, or 5.5 or 5 came up twice?
These are early OBD codes
https://www.google.com/search?q=95+Dodge+Dakota+sport+code+32+5+5
2answers
02 Dakota 4.7l. starts revs 5-6k than stalls. Replaced fuel pump module,tps,iac,map sensor,new hoses on evap, checked cat converter.
The best way to fix the problem on your own easily you need service and repair manual with diagram which will help you to fix the problem and you will get the manual from the given link http://toolsnyou.com/
I have a 1987 dodge Dakota, Ill drive it for about oh anywhere from 5-15 min. then it just stops running.
OK...an 87 Dakota is 30 years old now.....I'm guessing that there is something in your fuel system that is not letting the tank vent. Try driving the truck with the fuel cap loose or off and see if that helps...I think you may be drawing a vacuum on your fuel tank and it gets to the point where your tank pump can't push/pull any more fuel out of it. Try the above and see what happens...
I have a 1995 dodge dakota 4 cyl. and standerd trans. I just replaced the head gasket and it starts and runs great when it is cold but after running for a few min. it stumbles and has low power, it will...
have you done a back pressure test on the catalytic convertor? may have become clogged when the headgasket gave up. normally acts up after vehicle warms up and doesn't set an engine code.
92 dodge dakota 5.2 4x4 won't stay running, hard
What fault codes do you have? to check for fault codes using the check engine light blink method do the following, turn the key to run and then off, then to run and then off, then to run and watch the check engine light, count the blinks, there will be a pause and then more blinks, that is the code(s) So lets say it blinks 2 times and then 5 times, that is code 25. Google the code or codes under the heading: "Dodge OBD1 fault codes"
I have a 1990 dodge dakota 2.5 standard. The belt
bad water pump or air in system??? look for bleeder screws
3helpful
2answers
2002 dodge dakota runs for 5-6 mins then dies
it could be your timing chain and gears going out.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
